Status
Not open for further replies.
1 - 2 of 2 Posts
Discussion Starter #1
Any software around or techniques to use when a DVD hits a rough patch and freezes for at least a few minutes?
So far I have just been waiting, waiting, waiting..... Cleaning the disk does not help...........
Did you try a skip doctor type of cleaning? Those products remove a thin layer of the protective mylar to get past scratches. You can buy different cleaning surfaces depending on the depth of the scratches.
http://www.amazon.com/exec/obidos/tg...onics&n=507846
The've worked for me in the past.
If all heck breaks loose, try and dump the DVD to your hard drive with DVD Decryptor. It will take quite a while if there are errors, but it has saved one of my discs in the past
1 - 2 of 2 Posts
Status
