Peter,
Thanks for the response.....right now I have Swan Diva 5.1 floorstanding speakers with a Swan Diva C3 center. This is the reason why I had originally setup the room I guess you could say facing north with using the "flat" wall for the front wall. But now I am not sure because of the placement of rear speakers in the original setup. I think I would be limited to ceiling speakers for rears due to the door on 1 side & the window on the other......both plans would include a full length curtain on the window wall.
With the second plan I was not sure about speaker placement as the left & right front speakers would be much closer to the angled walls, but I would have a better place to install rear &/or side speakers.
Also, with the first plan, seating was not optimum as the first row is getting close to the screen.... 9ft I believe.
I am open to just about any suggestion regarding speakers & placement....
I had looked into the magnepan mmc-w's because they need to be angled at around 30 degrees which is very close to the angled wall in my room...
thanks again...I will try to post a drawing with the mmg-w's setup in the room
Joe
