I know the thread topic probably made a few of you say "You have to sound proof everything, otherwise it's useless!" But let me explain.
I don't have the budget or the need to go all out for a 50+ STC rating room. I just want to reduce as much sound as I can for my buck. For example, I currently have those hollow core $44 doors from Home Depot. Ewwww. If I can just do noticeably better than what I've got now, I'll be happy.
So I've spent hours researching new doors, door seals, door sweeps, acoustic caulking, buying Green Glue and laying down more sheetrock, etc.
Then I wondered "Isn't your sound proofing only as good as it's weakest link? I mean, the door I'm looking at (a Masonite Safe'n'Sound door mentioned on this site repeatedly) has an STC rating of 27. Plain studs with sheetrock I believe have an STC rating in the low 30s. The Green Glue will take the walls and ceiling up to an STC rating of 50+. Should I even bother with the Green Glue?"
So can any of you could help me out with this? Suppose I install the door right (with a good door sweep, acoustic caulking around the moulding, etc.). Will I notice any difference by using Green Glue on the walls?
