Status
Not open for further replies.
1 - 1 of 1 Posts
Hi,
I have connected the progressive component output of my Denon 3800 to Input A of my Sony D50. The picture looks great, but it's a little dim in dark scenes. So I looked into the manuals, because I wanted to know if the projector and the DVD player use the same signal levels.
The Denon manual says :
Y: 1 Vp-p 75Ohm
Pb: 0.7 Vp-p 75Ohm
Pr : 0.7 Vp-p 75Ohm
The Sony manual says for Input A HDTV Y/Pr/Pb:
Y: 1 Vp-p +-2dB, 75Ohm
Tri-level sync: +-0,3Vp-p
Bi-level sync: 0,3 Vp-p
Pr/Pb: 0.35Vp-p +-2dB 75 Ohm
Now I wonder if that's an error in the sony manual, because I don't know a component format with 0,35 V p-p o Pr/Pb or do the projector and the DVD player not match?
regards
Markus
1 - 1 of 1 Posts
Status
