Hi All
In the run up to getting an HTPC I tried to connect my laptop to my Barco 708 data CRT projector via its external monitor output,
The cable I am using is a VGA to 5 BNC, colours of the BNC are red, green, blue , black and white, unsure where to connect the black or white, my Barco only as 4 BNC connection which are RGB-S or (R-Y)Y(B-Y)-S, and there is a compersit
When I connect up the cable using the black BNC nothing seem to happen, but when I connect up using the white BNC I get a picture in RGB mode but it is rolling from top to bottom, if I select the component mode again with the white BNC there is a thick black line down the middle with the left side of the screen on the right and the right side of the screen on the left,
I am I using the right cable? Can any one help, don’t won’t to get an HTPC and find it does not work.
Any other pointer or advice would be great
Thanks in advance
Steve
Thanks in advance
Steve
