1 - 6 of 6 Posts
When I turn on my PRO 111 sometimes a wierd thing happens.
Its almost as if there is water or some type of liquid bubble that quickly disappears as the tv turns on.
It's when the screen is black it looks like a puddle that is drying up.
Has anyone else ever seen this in their tv?
Would be curious as to what this is and if it tends to happen with plasmas in general, Pioneer tv's or just this set.
Thanks in advance.
interesting. i have no idea. hopefully somebody can help.
I think thats moisture. this is from the manual on page 131.
Physical Location & Temperature Considerations
Condensation may form on the surface or inside of the flat panel TV when the panel is moved from a cold place to a warm place or just after a heater or air conditioner is switched on. If condensation forms, do not turn on the flat panel TV until all moisture evaporates. Powering on the display when there is condensation may cause the panel to malfunction.
It looks like you shouldn't be turning on the TV with that moisture in there. is the area cold where you have the TV?
how quickly is it disappearing?
Thanks in advance.
Mine does it also.
http://www.avsforum.com/avs-vb/showt...=#post16125185
1 - 6 of 6 Posts
