1 - 2 of 2 Posts
Is there a plan for any third party app to support this? I cannot really convert my Blurays to MKVs using MakeMKV unless a software player can play it back as well as my PS3 can. Any ideas? I will probably buy a new Mini if this is possible.
From what I understand, Apple will probably never support any bluray standards. I have come around it, installing Windows on a separate partition, and setting up MPC to run the hd sound formats. Windows seems way more stable outputting bitstream surround signal to my receiver (+ picture ofc) - never any glitches or pops. I can really recommend this. And when it is possible, just drag the appropriate m2ts file out from the bluray directory and save the encoding time and quality.
1 - 2 of 2 Posts
