Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I use a DAVIS Powerbeam LCD projector for "mobile" use (at home I´ve got a CRT monster). Now, the remote got lost during mobile use :) and I urgently need a replacement that doesn´t cost me more than the projector is worth.
I just had a remote from a friend who owns a DAVIS DL 450,
and it works with the Powerbeam. I tried to teach it´s codes into the learning remote of my EAD theater master - didn´t work. Tried the same with the learning remote of my girlfriends DENON AVR-1400 - didn´t work.
Any ideas?
A big thank you from the word of CRT!
Philip
The Pronto CCF's are pretty good... Obviously a pronto ain't a cheap fix but an early model on ebay would be within reason..
Also I have seen an identical remote to the Davis on one of the smarthome sites (x10.com smarthome.com ????) that looked identical and was being sold as an IR mouse remote... IIRC it was still $199 so a pronto looks your best bet...
[email protected]
HTPC without using windows... GUI Front Ends for Home Theater
1 - 2 of 2 Posts
Status
