Status
Not open for further replies.
1 - 6 of 6 Posts
Check with Curt Palme, I bought a cable from him that was supposedto be 14 pin, and turned out to be 10 pin. I returned it.
You could also watch ebay, I've seen a couple sell there. And try www.markertek.com , I think they carried it at one time, but I'm not sure. VDC might have some kicking around. I think the connector is an industry standard one, if you have the pinouts, you could also make one. The cable only has RGBS and a control line in it(I've cut the end off one) so only 5 of the pins are used. I think you coudl even determine the pinout by tracing the leads in the switche itself.
It's pretty easy to trace the leads on the input card itself as well...
Discussion Starter · #6 ·
I was just thinking... now that I have an IR remote, I really don't need to do this anymore! I wonder if the switcher boosts the signal... All if the extra boards in the chain can't be too good...
Sean
1 - 6 of 6 Posts
Status
