Where is the exact location of the "Remote Control Sensor" on the PDP-5020FD ?
876 Views 1 Reply 2 Participants Last post by  dssturbo1
I want to attach a stick-on IR emitter to the bottom right of the PDP-5020 bezel, however the location of the IR receiver shown in the owner's manual on page 8 does not seem to be correct. Can anyone point me in the right direction (photo or distance from bottom&right bezel edges)?
Thank you in advance.
-melgon
1 - 2 of 2 Posts
on my 60" elite it is about 1/2" up from the bottom and 3" from the right edge.
maybe a little different on your 5020 but you should be able to take a flashlight and see it pretty easily, then place your IR emitter over the round sensor eye.
1 - 2 of 2 Posts
