Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by Xcessiv /t/1517756/where-should-i-locate-my-subwoofers#post_24356267
Thanks for the feedback. Can I use the Audyssey mic on my HTR8063B mic as well?
Which sub would you put front and which one back?
I just bought a PB12-NSD, currently have a Velodyne F1500.
The F1500 is on its way out, the knobs sometimes cause it to stop completely. My hope is that the PB12-NSD will be able to provide enough bass alone once the F1500 retires.Quote:
Originally Posted by BeeMan458 /t/1517756/where-should-i-locate-my-subwoofers#post_24356462
What ever is chosen, a sub is best served nearfield behind the (MLP) main listening position.
No rules that I know of regarding sealed vs ported placement issues.
As soon as you can, sell the F1500 and purchase a second PB12-NSD. Sonically, mixing and matching dissimilar subwoofers, gets messy real fast as due to acoustics in a room, subs don't play and get along well with each other and the further apart subs are from each other, the worse the problem becomes.
F1500 specs and manual
SB12-NSD specs.
Technology between the F1500 and the SB12-NSD differ considerably. The big one is the LFE channel vs two RCA input technology.
Originally Posted by Xcessiv /t/1517756/where-should-i-locate-my-subwoofers/0_100#post_24356640
Follow AustinJerry's excellent guide:Quote:
Originally Posted by ahmedreda /t/1517756/where-should-i-locate-my-subwoofers#post_24356172
The best way to do it is to download the REW software and use it to measure the response and try to get one as flat as possible by trying different locations. This will require you to buy a microphone such as the UMIK-1 which can be found URL= http://cross-spectrum.com/measurement/calibrated_umik.html]here[/URL ].
I should have clarified this first, the PB12NSD is ordered already and 2x600$ is way out of my budget.Quote:
Originally Posted by flickhtguru /t/1517756/where-should-i-locate-my-subwoofers#post_24356678
I agree with not even using the F1500 and getting a 2nd PB12NSD. You can do the sub crawl to help you find the best spot for your secon sub. BUT you may want to try on the right side wall just behind your couch and kinda below the surround right speaker that should give you some good tactile feeling there.
Originally Posted by BeeMan458 /t/1517756/where-should-i-locate-my-subwoofers/0_80#post_24356462
Originally Posted by Xcessiv /t/1517756/where-should-i-locate-my-subwoofers#post_24356788
I should have clarified this first, the PB12NSD is ordered already and 2x600$ is way out of my budget.My mistake...![]()
Originally Posted by bear123 /t/1517756/where-should-i-locate-my-subwoofers/0_80#post_24356819
If you don't have room measurement equipment, the subwoofer crawl is the best way to place the sub.
Originally Posted by basshead81 /t/1517756/where-should-i-locate-my-subwoofers/0_80#post_24356768
Do the sub crawl as mentioned. Subs normally perform best where they asthetically look the worst, but hey all we care about is good sound right.![]()
Originally Posted by basshead81 /t/1517756/where-should-i-locate-my-subwoofers/0_100#post_24356768
Originally Posted by bass addict /t/1517756/where-should-i-locate-my-subwoofers/0_100#post_24356810
I'd disagree with this assessment.
Originally Posted by BeeMan458 /t/1517756/where-should-i-locate-my-subwoofers/0_80#post_24357227
Well, that's a first.![]()
Originally Posted by bass addict /t/1517756/where-should-i-locate-my-subwoofers/0_100#post_24357282
I'd disagree with that too. I've disagreed way more than just once.![]()
