Status
Not open for further replies.
1 - 7 of 7 Posts
My screen design calls for at least a 60" wide bolt of blackout cloth. The blackout at Joanns and other stores is usually about 55" wide. Where can I find some that is actually 60"? I'm leaving in about 90 minutes to go to work and I wanted to get some while I was out. Anyone have a fast answer? Otherwise I will have to resort to sewing 2 pieces together. :(
The only pieces I found were 54" wide :(
After some heavy pulling, streching and stapling I managed to get it to 56" in my frame.
I guess that was not the answer you were looking for.
Mark
u should use duck cloth over blackout cloth anyway.... it's avail @ joann's in 60 in for $6.99/yd :rolleyes:
duck cloth has amazing properties on wood frames.
i would think sewing anything together would be a disaster for a screen.
CLICK ME
I suggest artist's canvas. They should have 60 and 72" widths but avoid the pre-primed as it may crackle when you stretch it.
OIC :)
It's a bit rough as is but you must gesso/prime it after stretching on a frame. Raw canvas/blackout is a piss-poor performer.
1 - 7 of 7 Posts
Status
