1 - 6 of 6 Posts
· Registered
I am looking for a nice unit I can frame into my wall. Can anyone give me some ideas where I might be able to find one?
· Registered
I just got a pair of rack rails and mounted them in a framed-out opening that was about 19 1/8" wide. Much cheaper than buying a full enclosure (like the MA Slim-5) and sliding it in.
Something like this: http://www.sweetwater.com/store/detail/RRF21/
My rack during the framing stage:
· Registered
Jamis,
I think you just solved my problem. I am also installing my cabinet under a set of stairs like you did. I was wondering if I could use some pieces of a slim rack system and make it work. I was concerned it might need support in the rear, but it looks like you don't need it. Should I forsee any problems with that type of set up?
1 - 6 of 6 Posts
