Where to get Revo 7.1 mini-RCA cables
367 Views 10 Replies 10 Participants Last post by  Shawn Pilichis
I'm looking to hook up the Revo 7.1 to my receiver with analog cables so I can play coral reef... where can I get some decent ones? Rat Shack?
Chris
Status
Not open for further replies.
1 - 11 of 11 Posts
I bought some RCA/mini adapters at Rat Shack. Had to sand down the sides just a bit to get them all to fit side by side.
Chris
I believe monster cable sells something that will do this. Its intended as a way to connect an ipod to a stereo, they call it an isplitter.
DanW
See less See more
If you're crazy you could get some Kimber Cables PBJs from Headroom, http://www.headphone.com/layout.php?...tID=0050160160
I've got one and it's really nice, if I had income I'd probably get two more.
Belkin also makes a 1/8" to RCA now. its designed for the ipod, but it will work for this purpose. $9 at best buy last i saw.
I asked this ? today.It was suggested to go to radioshack.I bought 3 pakages of Y-adapter audio cables.6ft.,1.8 shielded stereo cables.Came out to be $22.00 total.
Are these the right ones?
http://www.radioshack.com/product.as...t%5Fid=42-2551
And am I just a naive consumer prone to be swayed by monster cable advertisements, or should I rightly be concerned about sound quality (particularly since it's an analog signal) hooking up my card with $7 cables???
If you are worried about being suckered then chances are you'll never notice a difference. Only those who have the audiophile faith are going to distinguish any difference. (And I'm a guy driving 3 aragon palladium monoblocks and 2 aragon 8008x3 amps with my Revo)
I am using something like these.
These allow to use your normal RCA interconnects. The ones on my L/R mains are gold plated :D
sangel,
I own that very set you linked from Radio Shack. I used them for high resolution audio capture from a SACD and the quality is superb for such a cable. I will be buying more when I do my next upgrade.
1 - 11 of 11 Posts
Status
