I have found really good placement for my floorstanding tower speakers (B&W cm10s) but i am having a hell of a time trying to fit my component stand into the setup where the cables will reach and it still fits aesthetically and functionally.
Does it matter how close a component stand is to the right or left main speakers? mine is currently off to the right of my front right speaker and only sits about 2 feet or less from side of the speaker - it is currently directly to the side as well, not front or back. Would it benefit me noise/distortion and sound quality wise to move the compnent stand say forward and maybe angled in towards the MLP so it is not so close to the speakers?
I have an A21 and JC-2 from parasound, with a marantz ud7007 blu ray player and benchmark dac2dx (might return this actually) all in the rack. I also recently purchased the halo integrated amplifier from parasound and that is on my rack for now but will ultimately probably be moved to a second set up (might be in same room or may not be) with some KEF ls50s that i just got as well. I have two svs sb2000 subs and my surrounds are completed with CMC2, cm5 from B&W.
I have purchased some materials to build a DIY amp stand for the A21 in order to make room and the rack but that is just creating more of a space issue as i dont want my speaker cables to be longer than like 12-15ft max.
thoughts on best placement? does it effect sound in a significant way to have components like a power amp close to a speaker or to the side as opposed to in front and out to the side or behind and out to the side? my wall is 17 feet but limited by a door on the front left side.
