1 - 4 of 4 Posts
I've narrowed down a few choices but I am open to others.
- Samsung LN32B650 (if it's still available anywhere)
- LG 32LD550 ( not a big fan of LG )
- VIZIO XVT323SV ( I feel like Samsung and Sony are better brands)
I will be using as a monitor also, so I need the text to look smooth and not pixelated (and obviously TV must be 1080p).
When I looked in the stores, it seemed the Samsung's had the best overall picture.
Wi-fi would be convenient, but I understand you can get after-market wifi.
About the 120hz: I've read this only matters on live broadcast TV and not movies.
I feel on the 32-inch that there is a noticeable difference between 60hz since I've read a most people feel you need 40+ inches.
I'm sure there are more TV's out there that I can compare with (like one of the Sony XBR's?) Any suggestions ?
My price range is about $300-$400.
This will be used in small bedroom (under 15feet viewing distance) but could be eventually used as a living room TV.
That Samsung is over two years old, don't bother looking for it. Sony doesn't make small XBR's anymore. Vizio maybe a decent choice, you may have to increase your budget if you want a 120Hz LED/LCD in a 32 inch size.
1 - 4 of 4 Posts
