chek out the Jamo S 803 series
You are going to laugh but it is not that unusual.Hi to all,
this is my current configuration.
- I've a Pioneer VSX 831 receiver (6 ohm) with a home cinema kit. Using for 65% music and 35% cinema. For the latter please note I give more importance to clear dialogues than blasts and booms
- I can't raise the volume too high due to neighbors
- I do not want to buy a subwoofer (for now I would consider it a nice to have, not a must)
- I must insert the speakers in compartments of the bookcase (closed compartments of 50 x 40 x 30 cm): so no more than 15-20cm between speaker and wall. No floor stands: husbands will understand me.
I summarized the following options, realizing that it's useless to spend too much money but I need to find a quality compromise.
Solution 1: use home cinema with a 5.1 kit. Maybe finding a good bargain for a good brand kit (like Wharfedale DX2?). Total: 200-400 euro. Honestly the option I like least.
Solution 2: a good soundbar below 300 euro (rather found in second hand market), but sacrificing the musical aspect (I hate soundbars because those heard have a boxed sound). Surely I will never spend more than 300 euro for a soundbar.
Solution 3 (spending about 300-400 euro): sell the AV receiver and buy a Canton DM sound station-base (no hdmi) or Yamaha SRT 1000 / 1500 (or others). I will put it under the TV. I call this option "the compromise".
Solution 4. Buy two active speakers (i.e. Edifier 1700, Presonus Eris...) with bluetooth for smartphones/PC and connected to TV. Total: less than 200 euro.
Solution 5. System 2.0 with two three-way speakers like Yamaha NS-B330 or NS-333 or Sony SS-CS5 (or others) attached to the Pioneer receiver giving up the subwoofer and the center speaker but obtaining a minimum of bass. About 200 euro in grey market.
Solution 6. Two good passive bookshelf speakers for a 2.0 system. The ideal choice would be choosing a speaker that guarantees at least some bass. But the biggest problem is the position in the library that should lead me to exclude all speakers with the bass reflex port in the rear. After a quick search almost all of the speakers I like have a rear bass reflex.
In order of preference:
KEF q150: rear
Audio Monitor Bronze 1 and 2: rear (?)
Kef q100: front
Mission LX-2: rear
KLIPSCH 41 and 51: rear
Dali Zensor 1: rear
Wharfedale 11: front
Other ???
That being the case, what would you do? Thanks in advance.
Due to the 3 factors I highlighted in red, the only and most obvious solution = the front-ported KEF Q100. It meets all 3 criteria, and IMO actually sounds better at moderate volumes than loud.Hi to all,
KEF q150: rear
Kef q100: front
Mission LX-2: rear
Dali Zensor 1: rear
Other ???
As an added note - the KEF Q150s come with bungs to put into the rear port (at least according to Crutchfield), so they can be sealed.Hi to all,
KEF q150: rear
Kef q100: front
Mission LX-2: rear
Dali Zensor 1: rear
Other ???
I suggest you go with front ported or sealed. A good sealed option would be the nht super one 2.1.Thanks for your suggestions. This is my new short list, in order of preference:
Looking for special offers/second hand:
1. Monitor Audio Bronze 2 / Kef Q150
2. Canton 502 / Canton 50x
New:
3. Q Acoustics 3020 / Kef Q100 / Dali Zensor 1
4. Jamo S803 / Wharfedale 225 or 11.2
I'll try to listen in some store (but not so easy to do), in the meanwhile I could judge only on Youtube reviews and sound tests.
How do you compare this to Monitor Audio or Q Acoustics?For Canton go with the Chrono 512 and up
For me they are better than the Q Acoustics -- and I would take them over the M A Silver that I auditionedHow do you compare this to Monitor Audio or Q Acoustics?
If you can find some Q Acoustics Concept 20s used they are excellent.Thanks for your suggestions. This is my new short list, in order of preference:
New:
