I built a HT in my basement where a good off air reception is next to none and im using a projector down there that has no tuner.
Im looking to pull some channels to watch football games when the new season starts.
Wich box would you guys recomend?
I have DVI, componet, Svideo and composit inputs but ide prefer DVI or componet outputs on the box to use. RGB also if its possible.
I probobly wont be using an antenna i can run a cable to the room but since i wont be watching tv down there i didnt want to get another cable box from time warner that they charge extra per month to use.
I found one called a "PHD-205LE ATSC / QAM (HD) Tuner Receiver Box" for $140.
Is there any better options? the PHD-205LE has all the outputs and stuff i want but im wondering if there is somthing a little cheaper?
