I have a number of tivos and, in fact, most of my viewing of media is stuff I've recorded and DVDs. I cannot adjust my schedule so that I can be home at '7PM' to watch a particular show. For this reason, I absolutely feel that high definition is a bit of a loss for me. However, I'm only using a Sony 32" tube tv at present and I can definitely see the benefit in getting a much larger monitor/display. Front projection isn't really possible as this is my living room and there are windows both along the right and left walls of the room (living room is about 20x12, tv viewed in the short dimension). I've looked at the Mitsubishi Diamond Net Command units, the 55" version. I'm leary of going any larger because of the shortness of distance now between couch and tv. I'm also considering the Pioneer Elite units but I'm trying to figure out if plasma would suit my needs. I'm also aware that there are devices that can be used to significantly improve the feed coming from my tivos, satellite box, etc (when I mentioned line doublers, one person i was speaking to said yes this device does something like that but a lot more, signal cleanup, etc. and so forth). My problem is I have no idea what this black box device is or would be called, I only know from this person that it's estimated to run about $5k for a TV like the Mitsu Diamond NC 55". Is the Pioneer 50" plasma superior to these options?
Additionally, I am also factoring in using the tv as a computer monitor (hence the Net Command etc.) although I'm beginning to think I'll just get a 17" LCD screen and mount that next to the couch instead.
Any thoughts/help would be appreciated.
