1 - 6 of 6 Posts
Hi all,
I just purchased my first pj and I'm loving it. I picked up the Viewsonic Pro8200 and so far the performance and quality has been great. Now I'm ready to get this thing off the coffee table and decide on a mount. Can anyone give me any advice on mounts or happen to know which mount would fit the Viewsonic Pro8200?
I'm looking for either a ceiling mount that hangs down at least a foot or so OR a wall mount so that I can hang the projector about 3/4th up the wall. Ultimately, I need to have my projector about 1-2 feet from the ceiling due to a support beam that hangs down between my projector and my screen. (Of course, I dont want the top half of my movies hitting this support beam from the ceiling).
I went ahead and attached a picture of the mounting holds on my projector.
Thanks for your help in advance!
Projector Bottom.JPG 2237k .JPG file
I use a cheap universal mount from Monoprice for my HD33 but if do-it-yourself is okay check out the Monkeyman mount thread (you'll need to do a search).
Don't go cheap on ceiling mounts.
For ceiling mounts, you will most likely need a extension pole to get a 1-2 foot drop, which most mounts support.
You also want to make sure you mount to a ceiling joist/stud, not drywall itself.
Select your projector manufacture & model in the links below.
http://www.chiefmfg.com/Projector-Mounts
http://www.peerlessmounts.com/default.aspx
*Once you locate the part/model numbers, you can find them relativiely cheap on amazon or other sites.
The AVS store also carries some of these mounts.
This makes a good rear wall mount shelf for a projector.
Just make sure it's bit enough for your projector.
http://www.amazon.com/OmniMount-ECSB-Component-Shelf-Accessories/dp/B000EGI7V4/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3TPTHWCNQ1YWT&coliid=I32GQDCLST8BE
I can vouch for the build quality of the sliding/tilting model on this page at Monoprice. It's made very well and could be a good choice if you need to get your projector away from the wall a fair distance. Wall Mounts at Monoprice
bonmot
Discussion Starter · #6 ·
Great! Thanks for the input, fellas. I'll continue researching with these links. I'll let you know what I ended up deciding on!
1 - 6 of 6 Posts
