Yes, but you don;t need to:
By default Windows doesn't allow USB devices to wake the PC from S3 (standby). When your PC goes into standby, the power is effectively cut to most of the PC, including (again, by default) the USB ports. The act of losing the power to the USB port creates a 'USB event' which is interpreted as a wake up command, hence your PC would start up immediately after going into standby. The trick is indeed to ensure the receiver is powered, but rather than attach a powered hub, most motherboards have a jumper which allows you to set one or more USB ports to be powered by the 5V SB line rather than the regular 5V line, which means that your receiver will remain powered in standby, and voila! Problem solved.
Just be careful not to put all your USB ports onto the 5VSB line - it can not normally supply enough current, and I have blown a PSU before now doing this. Just set the port you will use for the remote, and you'll have no problems.
