Status
Not open for further replies.
1 - 1 of 1 Posts
all i want to do is use my HTPC for its dvd drive and powerstrip abilities for the video part (out to either a z1/x1/or hs 10, have not decided yet) and send the digital audio stream from the movies out the pc to my reciever which would do the decoding/amplifing. So all i really need is a card with either coax or optical digital outputs, correct? I dont care if it is on the back of the card or in a separate drive bay module (the output). what is the least expensive card that would allow me to do this??
1 - 1 of 1 Posts
Status
