1 - 6 of 6 Posts
please
currently have an onboard Realtek chipset (on a Gigabyte 9400 based board)
but you can only fix the SPDIF sample rate output, fine for AC3/DTS which is uneffected but a pain for CD playback, trailers playback etc
all I'm looking for is say if its 2 channel 44khz back - 2 channel 44 khz is output
if its 2 channel 48khz - 48khz is output etc etc
at the momentI can only fix it at one specific sample rate
Premium Member
The Realtek audio chip supports 16/20/24-bit 32k/44.1k/48k/88.2k/96k/192kHz stereo LPCM over S/PDIF. You just have to bypass Windows Audio Engine that always resamples audio streams to whatever bit depth/sample rate you choose. Use a DS player+ReClock, foobar2000 or MC13 in WASAPI exclusive mode.
Premium Member
If your OS is XP use foobar (or winamp) and kernel streaming plugin. You could also check and install ASIO4All.
Premium Member
Yup, if your OS is XP, use Kernel Streaming. (WASAPI exclusive mode is for Vista/Win7.) The filter/players I mentioned support KS too.
1 - 6 of 6 Posts
