1 - 2 of 2 Posts
Got my P50S30 yesterday and now would like to hang it on the wall. Amazon has great pricing on wall mounts compared to retail and was wondering which wall mount other AVS'ers have used. I plan on fishing the wires through the wall and because I want to do that I am thinking that a tilt model - even though I don't want to tilt the set - might be better as it will give me a little more room behind the set.
Thoughts?
Premium Member
The fixed wall mounts at Monoprice dot com are very popular here. You don't have to spend a lot on a fixed/tilting mount, all of them are plenty strong enough as long as you don't exceed it's weight rating. The more important thing to pay attention to is correctly pre-drilling the pilot holes for the lag bolts.
1 - 2 of 2 Posts
