1 - 1 of 1 Posts
Premium Member
I have an SMX screen and would like to replace the screen material with a Gain of 1.3. For those that own the frame you know that it has a unique material mounting system that the material has to be stretched and secured in the frame channels. The material can't be too thick but too thin probably wouldn't work either. That being said, I assume someone out their has successfully replaced the material in their SMX frame.
Any suggestions would be appreciated. Once you did find the material, how much extra material over the frame dimensions did you order to help in the installation?
Ron
1 - 1 of 1 Posts
