I am completing our whole apt audio setup (speakers in all rooms for audio & 5.1 & 7.1 in 2 rooms). I have dedicated a closet for the full rack of AV equipment and wanted some advice. 34 total speaker runs, 4 hdmi, 8 ethernet, 2 USB & 1 3.5mm audio).
All cable runs (speakers, HDMI, ethernet, USB & 3.5 audio) are run through the walls from the speakers/room volume controls and I'm not sure if I should connect all the wires above DIRECTLY to the amps/receivers/distributors with cable looms OR set up a keystone media plate (or several as it would be) in the wall and use a separate connection from the wall plate to the amps/receivers/distributors. Maximum run for the HDMIs is 30 feet (single cable) and speaker cables are max 65 feet with 12 gauge wiring.
I know that there is a possiblity of degradation with each connection, but it would allow for a much more elegant solution in the closet (i'd be able to label all the keystones etc). Is the possible degradation worth a clutter-free organized closet?
Your expert advice is greatly appreciated.
