1 - 4 of 4 Posts
For my Win7 HTPC I use the Core Temp desktop gadgets to monitor my systems temps. But gadgets don't work in whs2011. Are there any programs that monitor CPU and system temps, either locally on the server or ones I can use to remote into it? Otherwise the only way I can currently do it is by going into the BIO during reboots.
The gadget just gets its readings from the Core Temp program. Check out their website, they also have remote monitoring using a server plugin.
CPUID HWMonitor and Speedfan are two more to add to the list
1 - 4 of 4 Posts
