Of course this is less of an issue in Europe - where it is likely that MPEG4 will be used for the new HD systems due to launch late this year and early next. Both HD-DVD and BluRay are likely to support MPEG4 recording. Of course the chances of any European STB outputting MPEG4 data is pretty much zero - it looks like some boxes will only have HDMI (not even analogue component) outputs...
AIUI one BluRay win over HD-DVD is that the BluRay camp have produced a 3 layer sandwich, which allows a single 25Gb BluRay layer and 2 DVD5 layers, to give you a 25Gb BluRay AND a DVD9 DVD on one disc.
The little issue with the much touted HD-DVD+DVD hybrid is that it only has a single DVD5 layer, not a dual layer DVD9. Think this may be because it needs a dual layer HD-DVD to get above the 15Gb single-layer HD-DVD limit? (Which won't be enough for a full-length decent quality film?)
I wonder if there will be clever discs in either format that only use the HD layers for the movie, and use th SD DVD layers for extras in both formats?
