Audiophiles don't hate entry level gear. They just don't like bad sounding gear.
Originally Posted by Raymond Leggs /forum/post/16896681
Why do audiophiles hate entry level gear so much?
I mean good speakers are good speakers regardless right?
Originally Posted by spyboy /forum/post/16896734
The problem is who determines what a good speaker is. I would say that audiophiles find it difficult to embrace the idea that a good bookshelf speaker can be had for $200/pair.
Originally Posted by penngray /forum/post/16896844
lol, I guess the next thread should ask....
"Why does anyone care what anyone else thinks about their setup?"![]()
Originally Posted by wgriel /forum/post/16896877
Now that's a good question! It's obvious people do care though -- lots of threads arise where folks are covertly looking for "approval" for what they've bought.
Originally Posted by Raptorsys /forum/post/16897351
I'd say there are two kinds of Audiophiles: the rich snob out to prove he's got the best kit, and the rest of us that cherish great sound. I won't concentrate on the snob and will only say that to buy almost any of the cheap stuff would be like going to Wal*Mart to buy quality furniture. Yes, Wal*Mart is cheaper but when the item lasts 3 months and needs to be replaced 5 times as frequently as "the good stuff" then the fact that you saved 60% doesn't pan out. In the long run quality is not only better but is, in fact, less expensive.
Now, I will add that even the non-snobs will sometimes bias a purchase in favor of the better 'name' even if there is no detectable advantage to it but the difference is that the snob almost doesn't care about the quality as long is it looks good and shouts, no I meen SHOUTS pricey!
Brian
Originally Posted by psgcdn /forum/post/16897435
Don't know about type 1. Some are convinced that my system is garbage for stereo because I use a home theater avr. Some are convinced you can't have great sound without a $3000 CD player, a $3000 DAC, a $2000 pre-amp and a $7000 amplifier. No thanks.
Originally Posted by 94GTStang /forum/post/16896766
It's just like the car community. Why buy the V6 mustang instead of the V8? It's just a never ending battle.
I for one would rather have a few dive vacations every year then high end speakers. Give me my Energy speakers and I'm good.
