1 - 20 of 65 Posts
· Registered
Hoping someone has some ideas on something that has been bothering me. Four months ago I moved to a new house and set up my speakers based on what should be ideal positioning but have been disappointed that in some ways the sound is worse than what I had at my previous house which had far from ideal speaker/listening positions. What bugs me specifically is that when listening to 2 ch music in my old room, I could pinpoint exactly where the singer's voice was coming from – it was very defined and I could picture exactly where the singer’s mouth was. In the new room, the singer's voice is not as defined and sounds like it’s coming from a larger area. It’s easier to me explain using a visual analogy – the previous sound was like a golf ball and the new sound is like a basketball. I think this is the case with instruments too but it’s most obvious/bothersome to me with the singer’s voice.
I’ve attached some pictures of the rooms.
Old room (don’t recall dimensions; speakers probably 1.5 ft off wall; LP up against back wall):
New room (24x19x8; speakers 3.5 ft from front wall and 5 ft from side walls; LP about 10ft from front wall):
The only culprit I can think of is that the old projector screen was solid laminate whereas the new one is a thin material and I have placed Owens Corning insulation panels between it and the window.
I’ve made some new acoustic panels with more OC panels and plan to hang them along the side walls this week but don’t anticipate them making a huge difference in this respect.
Any thoughts/suggestions appreciated.
· Registered
Your new room is vastly better than your old room. So part of the problem is you're just not yet used to the improved sound quality. However, you'll benefit greatly from acoustic treatment. In particular, your old room was open on the sides, where your new room gives strong reflections from the side walls. So in that one regard your old room was better. The good news is this is easy to fix. This short article is mainly about home recording, but all the same principles apply to hi-fi and home theater too:
Acoustic Basics
Once you apply some basic acoustic treatments, your new room will be far better than your old room could ever have been.
--Ethan
· Registered
Discussion Starter · #3 ·
Originally Posted by Ethan Winer  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23188598
--Ethan
Thanks Ethan, I've already spent a good amount of time on your site in the past.
I have already built 4 panels which are currently resting on the floor against the side walls (I"ll be hanging them this week); so far I can't say I notice much difference with them but hope getting them a few ft higher will help. I have 2 more sheets of insulation to build panels with - would you suggest the greatest benefit is treating the ceiling or next to the screen? My old room had a 10 ft ceiling and the new one is only 8 ft so I wonder if that's a factor. The brown panels in the windows are OC panels and they are basically right behind the mains but I could add another panel next to each of those.
Do you not think the window being entirely covered in OC panels is having adverse acoustic effects?
You might be right about needing to get used to the room but I don't think this lack of vocal definition will grow on me. In some ways it does sound better than my old room but I had very high hopes when moving here since I was able to set everything up based on ideal specifications in terms of speaker and listening positions; maybe my expectations were too high.
· Registered
Originally Posted by benunc  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23188380
Four months ago I moved to a new house and set up my speakers based on what should be ideal positioning...
Not sure what you mean by "ideal positioning" but, if you're open to placement suggestions, here's what I would do. If your room is 19 ft wide, then it will resonate at roughly 30Hz, 60Hz and 90Hz across the width of the room. You can ameliorate peaks & dips at those frequencies (across all seats) by placing your subs 57 inches in from the side walls and placing your left & right speakers 38 inches in from the side walls. You can further smoothen the frequency response by placing the seating at one of the 1/3 or 1/5 divisions of room length: e.g., 14.4 or 16 feet from the front wall.
Early reflections can have the effect of broadening the soundstage, like moving closer to the screen to get a bigger image. You can tighten the imaging and shrink the soundstage by absorbing early reflections from the side walls and ceiling. A demonstration of this was your old room, which had a higher ceiling and no nearby side walls, lessening the broadening effect of early reflections.
If the OC703 panels are sufficiently broadband in their absorbtion, then they will give you the effect you're looking for. In order for them to absorb directional frequencies, they should be at least 3-4 inches thick, placed 3-4 inches (air gap) from the walls. Panels that are too thin will only absorb higher frequencies, giving you a dull sound. Finally, consider covering more of your front wall with absorbtion; will keep reflections from your surround speakers from bouncing off the front wall and interfering with the phantom imaging in your front soundstage.
· Registered
Originally Posted by sdurani  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23189616
Hi Sanjay,
I've never seen a response quite so precise before, can you share the reason behind your calculations, and perhaps the formula? I'm intrigued.
Ben, just a thought but have you experimented with toe-in angle? You look to be 40-45 degrees, you may find that in the new and more symmetrical room somewhat less of an angle may improve your soundstage. It's odd I know, but sound can take on pretty big changes by moving your speakers even an inch.
Nice space! Don't spill red wine on that carpet (he said with the wisdom of experience
· Registered
Originally Posted by Nethawk  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23190233
Sure, there was some explaining in the REW measuring thread. Start reading from the following post:
http://www.avsforum.com/t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs/1080#post_22946030
· Registered
Discussion Starter · #7 ·
I followed Dennis Erskine's guidelines from a post I found while searching for advice on positioning.
Due to the way small rooms interact with speakers, the subs+bookshelf approach allows you to place the L/C/R speakers in a location for best imaging, clarity, etc. whilst the sub(s) are located in positions providing the better bass response in the seating locations. Further (assuming an 80Hz crossover between the mains/subs) you'd want your L/C/R's to be more than 3.5' from any wall (floor or ceiling) and your subs less than 3.5' from any wall. If you cannot get the mains more that 3.5' from a wall you'll need 4 or more inches of absorptive materials on all surfaces inside that 3.5' radius. (3.5' is approximately the 1/4 wavelength of the crossover frequency).
So, I set my LCR 3.5 ft from the front wall.
I found something else online regarding distance from side walls that stated mains should be at least 1.7 ft and 1.3x the distance from front wall; in my case this means the speakers should be at least 4.55 ft from the side walls and mine are over 5ft from side walls. I also read a guideline dealing with the difference between reflected distance of speakers to LP and the direct distance of speakers to LP; I don't recall the exact guideline but I think it suggested the reflected distance should be at least 5.5 ft more than the direct distance which my setup allowed. I found something suggesting a LP distance of 38% of room length. I think this is on Ethan's site. I'm around 40-42% which is as close as I can get due to the size of my screen. I tried moving my LP back which resulted in worse sound. I've tried varying toe-in and am happiest with mains pointed directly at the LP.
My acoustic panels are 2" OC703 and will be about 1 inch off the wall. Not quite what you suggest but hopefully enough to provide some benefit.
I have two sheets of OC703 left so guess I can try one on the ceiling and cut the other in half to add 1ft on each side of the screen.
Should one 2"x24"x48" panel be enough on the ceiling?
I have taken measurements with REW and am mostly happy with my subs' performance. I have the mains crossed at 80hz. There's a narrow null at 75hz but rest looks decent. I'll play around with placement more when I have time and think I can likely get an even better response. My concern is addressing the higher frequencies. I listen to music in stereo so the surrounds aren't a factor in what I'm experiencing.
· Registered
Discussion Starter · #8 ·
Yes, I've tried all degrees of toe-in and was most pleased with the mains pointed directly at the LP. Less angle created a wider soundstage but less precise imaging (basically the opposite of what I'm trying to achieve).
Thanks, I'm careful with the drinks but do worry about my friends after they've had a few. I'm actually installing a 2nd row of seating with a riser now (should be done this Saturday). Hopefully it doesn't have too bad of an impact on acoustics.
· Registered
I feel silly chipping in with all the heavy-hitters here, but it sounds to this amateur like a phase/polarity problem. Did you check the simple stuff first?
· Registered
Originally Posted by benunc  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23191290
Dennis mentions two alternatives, I put absorbtion on my front wall to avoid sacrificing 3.5 feet of space. The speaker/sub placement I mentioned had to do with cancelling width modes in your room. Cancelling peaks & dips across the seating area using speaker positioning means less reliance on treatments and equalization.
It will down to about 500Hz or so. I was suggesting more broadband absorbtion, down to around 100Hz, so that frequency response problems below that could be handled with subwoofer placement.
If you were to point a flashlight from your centre speaker to its first reflection point on the ceiling, you'd see a circle that is wider than 24". Sound doesn't travel like a narrow beam. So to catch the reflection of the centre speaker, I would use a 48"x48" panel centered at its first reflection point.
However, you're trying to catch the reflections from your L/R speakers, since you don't use your centre speaker when listening to 2-channel music. So you would need two of those panels, in order to be effective. You can have someone slide a mirror across the ceiling while you're seated in your main listening position. I doubt the ceiling reflections from both speakers will fall within one 24"x48" panel.
· Banned
I see the old room as being kind of irregular and chaotic, while the new one is neat and clean. In room acoustics irregular and chaotic can be very good and regular and clean can be very bad.
The new room needs more chaos and irregularity.
· Registered
Discussion Starter · #12 ·
Originally Posted by sdurani  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23191665
Since I had the room to move the speakers 3.5 ft off the wall, I just did that. It was cheaper and easier than adding at least 4" thick panels.
I'll try your placement suggestions this weekend.
Sounds like I need to buy another pack or two of OC703. I can use 4 sheet to thicken the 4 panels I'll have on the side walls to 4". And then sounds like I'd want 48"x48" on the ceiling; not sure I can get away with 4" on the ceiling due to the projector and screen height (I've since raised the screen from where it is in my picture on the earlier post).
Thanks for all the feedback.
· Registered
Discussion Starter · #13 ·
Originally Posted by arnyk  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23191739
Well I'll have a 1 ft tall riser with a 2nd row of seating up this weekend. I was worried that might have negative acoustic effects but maybe it will actually help. You can't see the back of the room in that photo but I have some bookshelves and a computer desk back there; so the room isn't as bare as it looks.
· Banned
Originally Posted by benunc  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23191829
Simply spacing 2" panels 2" away from the walls has pretty much the same effect as doubling the thickness of the absorbers tp 4"
· Banned
Originally Posted by benunc  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23191843
Bookshelves at least partially filled with books usually have acoustical benefits. Thing is they have to cover a high enough percentage of the wall to make a difference. Putting them close to the speakers may help.
· Registered
Originally Posted by benunc  /t/1467701/why-doesnt-my-room-sound-better-than-it-does/0_100#post_23188380
...What bugs me specifically is that when listening to 2 ch music in my old room, I could pinpoint exactly where the singer's voice was coming from – it was very defined and I could picture exactly where the singer’s mouth was. In the new room, the singer's voice is not as defined and sounds like it’s coming from a larger area. It’s easier to me explain using a visual analogy – the previous sound was like a golf ball and the new sound is like a basketball. I think this is the case with instruments too but it’s most obvious/bothersome to me with the singer’s voice. ...
Would you be surprised to find that some folks would prefer if your basketball were a beachball? (I'm one of them.)
There seem to be two schools, some folks prefer pinpoint imaging with very tight localization and others prefer loudspeakers that disappear into a diffuse, broad sound field. You're in the former group. and everyone's spot on in their advice to treat first reflections. Here's a link to Harman's white papers, and I recommend the second from the bottom, Part 2. The last 20% of this talk addresses imaging with a basic imaging test and some advice on options for improving it using absorbers and diffusers.
http://www.harman.com/EN-US/OurCompany/Innovation/Pages/WhitePapers.aspx
Arny's right about a little space being work lots of low end absorption, and you're starting with 2" panels, not 1" as shown, so your "0" airspace curve is for the 2"panel. You'll get plenty of absorption down to 100Hz with what you've already built if spaced from the wall a little.
Have fun,
frank
· Premium Member
I am so jealous. Your old room is EXACTLY like my existing HT area in my open basement. I have my screen on the wall of my staircase and my couch against the back wall. I am fully open on the left side of my room; and I have a wall 10' to the right of my screen.
Someday soon, when my kids are grown, I will either take one of their (rather large) bedrooms, or, move into a different house with a better suited room for acoustics.
BTW, my room sounds great; except for bass issues and reflections caused by the back wall. I am currently in process of purchasing bass traps for the back corner and wall, and, absorbers for my first reflection points on the right wall. Also, I just recently experimented by pulling my couch out from the wall by 33% of the distance from the front to the back wall. The improvement in the my bass and surround information is HUGE!! As a plus I am now able to install side speakers for 7.1. My drawback is that I am only 9 feet back from my 106" diag screen.
Congrats on the new place!
· Registered
Originally Posted by jdlynch  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23203623
When you watch 'Dark Knight', you get the IMAX effect at home. Hardly a drawback. Besides, your 46 degree viewing angle isn't as big as some of the home theatres I've seen locally.
· Premium Member
Originally Posted by sdurani  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23204495
Sanjay-
You and I are in full agreement. Would you do me a favor: Please call my wife and convince her that 9' is not too close?
David
· Banned
Originally Posted by jdlynch  /t/1467701/why-doesnt-my-room-sound-better-than-it-does#post_23204865
Sanjay-
I don't know if it is a gender thing or what, but I sense that many women are not comfortable with more immersive media experiences. Either they just want their space, or they are sensitive to the fact that immersion is often done badly.
1 - 20 of 65 Posts
