20 more points meaning 20 db?
Is your reviever 100% capable of decoding DolbyTrue HD?[/QUOTE said:
Originally Posted by MSmith83 /forum/post/0
I'm not sure if it has been fixed yet, but the second generation Toshibas have a significantly attenuated volume when outputting the decoded PCM signal at 96 kHz. Set the SPDIF output to "bitstream" in the player setup to force a 48 kHz PCM output over HDMI. It sounds silly (stupid engineers), but that's how it works.
I'll bet it is dialnorm (or lack thereof)...you need bitstream to get it.
Originally Posted by DocDVD /forum/post/0
Easy fix for this....with PCM set for both HDMI and SPDIF outputs, turn dynamic range control off and back to full volume.
Originally Posted by thehun /forum/post/0
All current DTHD from WB or Universal are either 16/48 or 24/48khz, so that shouldn't be an issue.
Originally Posted by gooki /forum/post/0
They're mixed lower to allow for greater dynamic range - ie better quality.
