Whatever...
your eyes must be broke.
Originally Posted by Ettepet /forum/post/0
vladi123456, what screen (or pj) do you use to watch HD?
Originally Posted by AustinSTI /forum/post/0
Is it possible the resolution on your plan is set to 480p instead of 720p/1080i/p? If its not that then something is wrong - take your HD-DVD player back![]()
What does your TV say the resolution is at when you hit 'display'?
Are you using component, RCA, S-Video, a Reciever that's supposed to upconvert, HDMI? Maybe if you have a reciever in the mix its downconverting...
Originally Posted by vladi123456 /forum/post/0
Last night my gf and I were watching Scorpion King on HD DVD, which happens to be a tier 1 title, and I accidentally pushed the Channel button on my TV remote and switched to channel 5 NBC which I get with an over the air HD antenna. And it was showing National Treasure with Nicolas Cage. That over the air movie in high definition looked a lot better than my Scorpion King HD DVD - it made me wonder what's up. Can anyone explain in simple English why HD movies (both HD DVD and especially Blu-Ray) for the most part don't look all that better than standard DVDs? And how can over the air HD broadcast look so much better? I think the difference was more noticeable than between standard DVD and HD DVD? Do they use different codecs for broadcast or is there any other reason? I'm just being curious....
EDIT: Changed the original text a bit - I'm not trying to say HD DVD looks bad - I just like the over the air HD Broadcast better. I've read somewhere that over the air HD broadcast is better than cable/satellite HD because the latter use more compression. Which I don't think would the case here
I'm using HDMI cables, and when I hit "display" - it shows 1080i. I'm almost prepared to accept the "my eyes are broke" explanation that some gentleman offered here in an earlier post - as I'm clueless why I can't see what other people see.
In the living room I have both HD-A2 and PS3 connected via HDMI to Onkyo 604 and from Onkyo via HDMI to a 52 1080p LCD Sharp. When I hit display button - it shows 1080i and 1080p for HD-A2 and PS3 respectively. But I still don't really see anything high definition in most of the movies I watch. For example, I watched "Click" on Blu-Ray - and it looked even worse than SD DVD in my opinion. Ironic, but the only hi-def stuff that look hi-def to me are those that I get via my over the air hi-def antenna - news, some sports shows and such. So maybe it's not the issue of my tv not beeing properly calibrated, but my HD players/PS3.....
