Pearl Harbour (PH)will not pass solid sound through to my denon 1802 receiver. PH is a dd5.1 THX movie. I have built my new HTPC so i don't know if it is a HTPC prob/software prob or video prob... or perhaps even a sound card prob.
To check the DVD i went and hired another copy, but same result... only sound is very faint coming from centre speaker. All other movies play fine, DD / DTS all played fine. sound is great, DD and DTS lights on receiver are displayed.
Even got Phantom menance to see if THX movies are the prob (could this be so, anybody had any probs with a THX movie). However this did play.
The menu in PH does not have audio options so you cannot select audio on the DVD.
Have tried powerDVD4 and Windvd 3.1 with a sb live DE5.1 card (s/pdiff out)
if i select 2 channel in Powerdvd through s/pdiff then i get suround sound... (receiver DD light goes out.. i assume digital does not get passedthrough then).
also when PH goes through its start up (displays THX) you hear the full sound, even up to the stage of menu selection... however when movie starts then no sound.
I've come to hte conclusion it must be movie specific or there is something special about THX movies that i don't know about.
any help appreciated... it's driving me nuts.
