Status
Not open for further replies.
1 - 12 of 12 Posts
· Registered
1. Wilmington, Delaware
2. 23 miles
3. A
The only problems that I've had since installing my antenna have been times where WHYY has reported problems. My antenna is chimney mounted Channelmaster 3021 and my receiver is a Panasonic TUHDS20.....
· Registered
I am conducting a survey for HD enthusiasts in the greater Philadelphia area, concerning the quality of reception for our local PBS digital station, WHYY-DT. In a nutshell, the station is broadcasting at very low power, and has no immediate plans to increase this power due to economic and market concerns.
However, the core argument for the station is that for folks who can receive the station's current analog signal, about 80% can ALSO receive the digital station without problems. Based on antedotal evidence over the past 12 months I believe that their premise is wrong; that the actual number is well below 50%.
Since their analog reception area should be at least a radius of 40 miles (local conditions non-withstanding), I'm trying to collect hard data to try to persuade WHYY-DT to increase their transmitting power as soon as possible.
Here's what I need from folks living OVER 15 MILES and UNDER 40 MILES from the Roxborough transmitting towers (please limit your responses to a quick answer to these three questions):
1) Where do you live?
2) How any miles do you live from the towers (if you know)
3) Describe your AVERAGE reception of WHYY-DT using these letter grades (A and B mean acceptable reception, C and below do not)
A -> Perfect reception virtually all of the time
B -> OK reception most (or all) of the time
C -> Off/on reception most (or all) of the time
D -> Mostly no reception most (or all) of the time
E -> Can't pick up the station at all most (or all) of the time.
I'm trying to get 100-150 responses. I need help here folks!
BrianDx.
(P.S. my response)
1) Downingtown PA
2) 25 miles
3) D
[This message has been edited by briandx (edited 08-30-2001).]
· Registered
Hightstown NJ
10 miles west of Princeton (~50 miles?)
B
JD Sherman
· Registered
Crap. Sorry.
I meant ~10 miles EAST of Princeton.
JD Sherman
· Registered
Burlington, NJ
around 30 miles??
B
Just reset my DTC 100 and this station just started coming in.... Also recieving NBC (so so) ABC and the best reception has always been CBS.. using a small Radio Shack antenna inside laying on top of the cabinet.. go figure Had a Terk TV55 and not nearly as effective.
· Registered
Lawrenceville, NJ
34 miles
C
BTW, do you think that this data is meaningful without knowing which tuner, antenna, pre-amp, mounting, etc... is being used?
Ed
1 - 12 of 12 Posts
Status
