1 - 4 of 4 Posts
Banned
1 of my xbox 360 slims has a problem its connected with HDMI to the tv it seems to be reseting it self back to 480p we have to change it back to 1080p ccould it be a problem with the xbox the tv or the HDMI cable?
What is the model of your display and what kind of HDMI cables do you have?
Why don't you try switching the problem xbox with the xbox that works fine. If the problem is now on the xbox that worked fine, it might be something to do with your tv. Maybe try a different hdmi cable while you are at it.
1 - 4 of 4 Posts
