1 - 20 of 23 Posts
OK, narrowed it down to a couple of choices all in my price range, my needs
- will be in a room where I have solid curtains so getting the room dark is not a problem
- Will do some light Wii gaming with young kids
- Will watch general TV, sports and movies as this is in the family room
- Will be hooked up to surround sound/receiver etc
Here is the list:
Panasonic TC-P54G10 $1,578 http://www.amazon.com/Panasonic-VIER...0345788&sr=8-4
Samsung PN58B550 $1,999 http://www.amazon.com/Samsung-PN58B5...=3F8GBCD2SRMQS
Samsung PN58B650 $2,299 http://www.amazon.com/Samsung-PN58B6...=3F8GBCD2SRMQS
Edit - now also considering the Panny v10 54" version vs G10, but wondering if worth the extra $700?
If I missed any models you think I should consider let me now.
Again, these are in my price range - I've heard good things about both brands but that's just general chat so I want the experts opinions - thanks all I appreciate it.
Cheers
Premium Member
I'd take door #1
BTW, there is a post purchase $200 rebate on the Panasonic TC-P54G10. so this would drop your total price to $1378. Seems like a good deal to me. I can't recommend any one of the sets over another though, as I am trying to decide on a plasma to replace my aging Toshiba Cinema Series 36" CRT.
NB
the B650 will support 24 frames rate and not the others....
so if you are going to watch blu-ray and don't 2:3 pull-down this is your choice
not sur ebut I think the b650 also has only one sheet of glass but the g10, has 2 which can be anoying
Yes, all the panasonics have that second sheet of glass. That creates "shadow" reflections when you're sitting off-center. Watching a baseball game recently, I found the reflections of the players white uniforms very annoying.
Originally Posted by thj17 /forum/post/17004993
...not sur ebut I think the b650 also has only one sheet of glass but the g10, has 2 which can be anoying
On the other hand, I wonder if the second sheet of glass also helps prevent the buzzing noise that is present on the Samsungs...
Here is the list:
Cheers
Wife will allow me
Just got the PN63B550. Works just fine for me. Your Panny choice is 54", while the others are 58". Depending on where you are coming from, that's a big difference in the viewing size. Don't have buyer's remorse. I'm glad I went with 63", since I'm "downsizing" from a 67" DLP. Any smaller and I wouldn't have been happy, in spite of PQ differences.
It's up to you on the feature differences between the B550 and B560 models. A good calibration can make up differences in PQ.
Discussion Starter · #12 ·
Thanks all, The V10 looks quite good, but not sure if I want to spend the extra money, I'll probably regret, but I think I'm going with the 54" G10 after reading plenty of reviews, etc.
Super Moderator
posts deleted: coupon & pricing posts are not allowed
please check rules in my sig
please limit your posts to technical talk
Discussion Starter · #18 ·
Is the v10 worth the extra money over the g10 - $800 diff on the 54" model.
Also www.abt.com has the v10 54" for about $450 more than I've found the g10 - worth it, anyone ordered from them - reputation good, I've never bought from them. http://www.abt.com/product/40809/Pan...-TCP54V10.html
I've read the g10 doesn't handle blue ray great at 48hz where the v10 goes up to 96hz.
1 - 20 of 23 Posts
