Status
Not open for further replies.
1 - 11 of 11 Posts
Hi,
I am new to HTPCs and have two questions (two I will bother you with that is):
1. I read about some people using a Toshiba PDA with WiFi to control a HTPC. What pocket pc remote control software utilizes Wireless LAN ? Could this also be used to control X10 modules for lamps ? Macros ?
2. I will keep my computer away in a "technical room", and only want the screen, speakers, remote control and an external dvd-rom in the living room. Could somebody recommend a slimline external dvd-rom (perhaps originally for a laptop) ?
3. Is there a program for the PC that can handle the X10 computer module, running apropriate video/audio software, remote control signals and has a nice graphical user interface ?
Thomas
 Here is a link
Next time, try the search button. It will save you tons of time. I did a slow search on "PDA Remote" and a few threads popped up that would have helped.
I'll be doing the same thing.
Do a search on HouseBot and Girder. The HouseBot will do what you want and they are setting up a bridge between it and Girder. The HTPC will be the server and the PDA will be the remote client.
I too am interested in the Slimline DVD player...whatever that is. I need an external DVD player so recommendations are appreciated.
I'm almost thinking I should skip th PDA remote thing and go for a cool RF keyboard/mouse combo like the Gyration(sp?).
For the DVD, do a search in this forum for 'external DVD enclsoure'. There are a couple of threads about using external USB 2.0 or firewire enclosures.
Where did you get this from? Did you actually do a search yourself and get links to legit threads?
I did a search with the following phrases:
usb AND external AND dvd
usb AND dvd
usb dvd
usb external dvd
external dvd
dvd AND enclosure
external dvd
dvd enclosure
firewire dvd
external DVD enclosure
You know what I got as a listing? THIS THREAD!!!! :mad:
When I told him to do a search on 'HouseBot' I know there are at least 5 threads out there which are recent with that as the MAIN TOPIC since I've responded to them all.
Hi bohtho,
HouseBot is really cool, but that requires a WinCE PDA.
MisterHouse.com can control X10 and many other things by voice command. I am going to try to it. You should look into that too.
Originally posted by aleet2600
Hi bohtho,
You could configure HouseBot to handle all of the X10, IR, automation, etc. You can then run the Software Remotes (clients) on any Windows machine, including the HouseBot server itself.
Scott
Not sure why you had a problem with the search. I did a search for 'external DVD enclosure' and got a listing of 21 threads. Among them:
Ahhhhhhh.... Thank you very much! I don't know why the search didn't bring these up either. I tried it again exactly as you did, but only 7 results and not related. Either way, much appreciated!
In regards to the extrenal Firewire, I have a similar setup.
My DVD is in an extrernal Firewire box (slavaged fomr an older Sony CD-RW) wooked to my HTPC via a 15' cable. This way the HTPC is tucked out of sight in an equipment closet. The setup works well, although I have had problems with DVDIdle using this setup.
As for the Wifi remote, check out NetRemote on this forum.
-Dave
1 - 11 of 11 Posts
Status
