I found a way to move the outlet over just enough so that the bracket will sit flush on the wall. I used the hole located at the top right of the outlet to screw it into the box. I then used the second screw to hold the bottom in place by placing it to the right of the lower arms (there's no screw hole on the bottom portion). Yeah, the outlet was slightly lower than before, but that wasn't a problem. The only problem then was the outlet cover, but I found a way to cut that without snapping it. I first tried with a hacksaw, but it just snapped into lots of tiny pieces. Second time around, I scored it with an blade a bunch of times, then I put a soldering iron to it to melt along those lines. Not the cleanest outcome, but I was going to paint the cover anyways. Not to mention that the cable management system will hang over the outlet a bit, so it'll be mostly covered. Had to cut the edge of the cable management cover so that I could still plug stuff into that outlet (only outlet near my TV). Thanks anyways guys and have a good weekend.
