Status
Not open for further replies.
1 - 3 of 3 Posts
Will 3 Barco 801s lens work with a Barco Data 800? :confused:
Mine are really scratched and I'm thinking of buying 3 used lenses.
They are Delta HD-8 rev B, removed from a Barco 801s.
Danny
hi danny,
no problemo. go for it.
i think you have the metal lenses on you 800.
these were the predecessors of the plastics.
the difference is the metals are all-glass and the plastics are hybrids.
the metals show a little more resolution and are less temperature critic.
but the advantage of the hybrids are better edge focus and a little more light.
-g.
Discussion Starter · #3 ·
Thanks g! I'll do that.
Danny
1 - 3 of 3 Posts
Status
