Status
Not open for further replies.
1 - 7 of 7 Posts
Just need a quick simple answer to this one - I decided to change my screen size... Thinking about doing a 72" wide in 1.85 format (72X40"). This puts me around 8ft lamberts with my ecp4100 in a light controlled room w/1.3 gain screen material (8ft viewing distance). Will that be enough brightness to look good?
--Eric
Kinda dim. Most of the setups I've seen look to be around 12-14 and people deem those "normal". I run mine pretty low (10-ish) so a full white screen doesn't blow my eyes away.
it`s up to you
but to me it would be way to dim
XANATOS
With that set-up it should be no problem to get 10-13 foot-lamberts reflected. I have had no problem getting that kind of light-output with any crt-projectors on a 80" wide screen.
Per Johnny
I ran my ECP 4100 with an 80" wide 16:9 screen. 1.3 gain. With total light control the image was good.
Consider painting the ceiling a dark colour, as well as the surrounding walls. This will help 'light control' in a big way (reflected light from the screen).
Going smaller (72" wide) will give you a satisfying image.
Roo
yes get a 100 inch 13 gain curved screen from vutec
you wont be sorry
XANATOS
1 - 7 of 7 Posts
Status
