I just bought a 2 piece +12db amp from Radio Shack for 100ft of coxial cable running from the aerial to the receiver. I dont have experience with a two piece amp...supposedly it's much better than a one piece amp. One piece is closest to the aerial, the other piece with power is closest to the receiver. I guess one pushes, while the other one pulls the signal...not sure.
Anyway, I want to know if adding an extra 12db would hurt or help 100ft of coaxial cable? It's not that easy to tell as analog reception.
Thanks for you help in advance...
-Michael
[email protected]
-Michael
[email protected]
