Status
Not open for further replies.
1 - 3 of 3 Posts
I noticed that Pacific Cables sells a DVI splitter cable (M/F/F). Has anybody tried this method for connecting 2 DVI inputs to a Sammy? The cable is $50, but would not require switching cables back and forth.
Here is a link:
http://www.pacificcable.com/Picture_...ataName=DVIY-2
Premium Member
The cable is discussed so incredibly often that you wouldn't believe it.
No, the cable will NOT do what you're asking.
It will split one source to two displays, and will NOT work the other way
around. Many people here have tried.
Discussion Starter · #3 ·
Thanks zvogt. I tried a search in the forums first but did find anything on it. I guess I will stick with switching cables.
1 - 3 of 3 Posts
Status
