1 - 7 of 7 Posts
I was able to get an exposure 2010s2 integrated amp for some pretty short money.
I am wondering how the amp matches with the b&w pm1. Are they a complimentary pairing?
I am not a specs guy but I would like to know if it's enough power and there are no clipping issues. The amp is 75 watts per channel.
Banned
Originally Posted by motobonsai  /t/1525404/will-an-exposure-2010s2-work-for-b-w-pm1#post_24557481
The power requirements for a system are based on listening distance, preferences for loudness (SPL) and loudspeaker efficiency. You seem to be holding 2 out of 3 of the cards.
if we had them, the next step would be to plug them in here:
http://myhometheater.homestead.com/splcalculator.html
These speakers have low efficiency (84 dB/W) and limited power handling (30-100 watts). A 75 wpc amp should be OK but hopefully loud listening is not in your future. A subwoofer would help, but the Exposure amp doesn't have nearly the support for using a subwoofer as an AVR would. You could probably work something out with the right sub that had its own line level crossover. The Exposure has pre outs but no amp-ins.
Discussion Starter · #3 ·
thank you very much. I do not intend to listen very loud at all. I am not a big fan of subwoofers. so i was hoping to not use one for stereo music. However the speakers would be in a medium to large room I know that is not ideal but that is the only room available.
Originally Posted by motobonsai  /t/1525404/will-an-exposure-2010s2-work-for-b-w-pm1#post_24561114
I was hoping for an amp a little better than fine. But this amp will have to do. Thank you all
In order to get "better" one assumes you mean better sound quality and that isn't a characteristic of amps. Fine means it is powerful enough to get the job done for you.
1 - 7 of 7 Posts
