1 - 3 of 3 Posts
· Registered
Yes an HDMI v1.3 cable will work, they are backward compatible.
I believe the only difference is a similar difference of Ethernet cables, cat5 has less throughput of a cat6 cable because the resistance of wire used or something on that line. Since HDMI 1.3 has the capability of a lot higher bandwidth it uses different standing of wire I believe.
· Registered
It will work for sending video over it. but some of the more advanced two away communication options between component and the TV will not work.
1 - 3 of 3 Posts
