Will this receiver be able to handle my center channel okay?
Whatmough magnum m05
* Configuration: 2-Way Bass Reflex
* Recommended Power: 40-100 Watts
* Nominal Impedence: 4 Ohms
* Sensitivity: 91dB
* Frequency Response: 70-20KHz
Room is 20"x20" and its a townhome with shared walls so I never really blast it for the sake of my neighbors.
Only using Front speakers for now...
It's in an open air metal tv stand with total ventilation to the receiver.
If it is safe should I be setting to 8 ohm small speaker? Im a n00b and didnt look over the specs of the speaker before I purchased it
The 6 ohm setting just lowers the rail voltage which limits power and decreases the headroom on transients. The transient power needed with most movies/music is something like 10x the average power and it's the average power that makes the amp overheat so the 6 ohm setting doesn't really prevent overheating, it just clips the transients correct?
Ive read yes, ive read no. Ive read if you dont turn it up too high....
Please help before fiancee makes me return everything for a theater in a [email protected][email protected]#%
* Sensitivity: 91dB
