Status
Not open for further replies.
1 - 5 of 5 Posts
I just bought a 30 inch lcd from philips. It has one component input and one hdmi input. I plan on connecting a DVD player (which one should I get, i want to spend ~75-100 market value, like ebay cost), a HD Digitial cable box (it is DVI oiutput so i need a dvi to hdmi cable), and a xbox using the HD component connectors. Should I buy a switcher for the dvd and xbox?
I am sorry if I sound like an idiot but I really need help. Thanks in advance!!
If you have three things to connect and two inputs, you need a switch. Unless you want to be reconnecting things constantly, which I wouldn't recommend due to possible wear on the connectors.
Premium Member
I'm just curious why you chose a TV with only two inputs when you know you needed three? :D
There are a number of Component switchers on the market that will make it all work.
1 - 5 of 5 Posts
Status
