361 - 380 of 397 Posts
Thanks! I prefer gamma 2.4 by the way, open up some more details in the dark areas.
I may have changed the gamma just to see what effect that had. If I were keeping it, I'd do more tinkering. But I need to send it back next week.
So in the video review the dark scenes from guirdians if the Galaxy looked pretty flat/poor.
Is it really that bad or just just his setup (wash out + who knows what hdr stack).
I don't have guardians of the Galaxy to make a direct comparision but I can tell you that its not that bad at all. Its not a perfet projectr and contrast its not its best quality but I'm globally satisfied.
This is my initial impression after about 50 hour.
What I like:
- Brightness is impressive, even in echo mode. A TV like experience
- Colors are intense, deep and natural
- Resolution is beyond my expectation, e-shift works very well and without artifact or any added noise.
- Noise in echo mode, the projector is not udible
- Ranbow in 50/60 Hertz is almost absent
- Lens shift and throwing distance is perfect for my room
- I can leave it on without worrying about the lamp duration. With two kids who use it insted of TV is not trivial
What I don't like (but I can live with)
- Lens quality is poor, lot of cromatic aberrations and halo on menu text (which is not so evident on screen)
- Noise in Standard and variable high/low mode is udible
- Noise in variable high/low (80% of light) is equal to noise in Standard mode(100% light). For reference echo is 70% of light and its dead silent. Hope a firmware upgrade can fix this.
- Native contrast can be better
- Rainbow in 24P mode is clearly visible to my eyes (i'm very sensitive), but I have accepted it.
- Focus has slight shift when projecter is cold/hot, again the lens is poor.
- The menu has a good style if we had been twenty years ago
- Lens shift do not have a zero position, so you don't know if you have it enabled or not and how much. Its a minor issue, but I don't like it.
- HDMI synch is slow and may happen frequently when the Apple TV output format is different than the content you are watching.
Thanks Giuseppe - as Craig knows, I am strongly considering this for my 135" screen in a non-dedicated workshop/mancave. Projector will be ~17ft from screen, ceiling mounted at 9ft and use will be divided between daytime/sports and movie viewing. Here is my thought process -
- full power when watching sports during the day. Usually with people over. Fan noise not likely an issue.
- eco at night should be plenty
- I don't see DLP rainbows
Pros:
No bulb dimming. Never have to change a bulb.
Cheaper than NX5 or Optoma laser dlp
Much brighter than NX5
Cons:
Contrast/blacks (but that will be hurt anyway by my space, grey/green walls, etc)
Fan noise (but ceiling mounted in eco mode should be ok, not an issue when watching sports)
Manual lens adjustments (but how often am I really going to mess with it? Not using panamorph, etc)
From the YouTube videos and pro-reviews out there, you'd think this was the worse projector ever. And I get it. If I had a dedicated space, this would be a non-starter. I would be looking at an NX5 or even an NX7 because the space could justify it. Or for the same price, something quieter/dimmer/higher contrast like an Epson for my quiet black room. However, for a non-dedicated space with ambient light (and ambient people), this seems like a great option.
Pros:
Cons:
If I was still in my old house with the projector in an open beam ceiling family room ( with zero light control ), this projector would be just the ticket. Or, as a 2nd projector for watching sports and HDTV with some lights on, it would be perfect.
Pros:
Cons:
What screen choice are you going to pair with that ambient light setup?
Pros:
Cons:
After watching the reviews.
Reading.
The uhz65 I feel is a better projector.
I have read the thread 3 times now.
The adjust thats available for picture is outstanding.
I really want to see a side by side on these 2.
My goal is 150 inch screen.
So I need the output.
Only other projector I am looking at is the 6050
The uhz65 I feel is a better projector...
Agree. Would also like to see them side by side.
The uhz65 is two years old, but has the .66 chip. Maybe better lens?
The JVC has auto-tone mapping, more lens shift (if needed) and is ~$1k cheaper
uhz65 is probably quieter. :D
Does anyone have a "in-depth" Calibration for this projector? (JVC LX-NZ3)
I have this unit, and will be doing a comparison on using Seymour AV Glacier White screen vs. Carl's Place Ultra Gray Screen material.
Trying to help those black levels a tad. Any calibrations would be great to see and try!!!
