1 - 6 of 6 Posts
I was wondering if I were to hook up all the HDMI connections and run the HDMI output to my projector. Then connect all my component inputs and run the component output to my TV upstairs. Will this work?
Thanks for any help
Vid53
What is it that you want to do?
There's only one multiroom output, and it's a composite signal. So you can't watch different sources in different rooms through the same outputs using component. On the other hand, I think you can watch the same signal in two rooms: the manual says that "the video converter ensures that all video sources are output through all of the MONITOR VIDEO OUT jacks".
That most likely works as they are likely independent circuits. Seems pretty simple to just try it out if you own it
1 - 6 of 6 Posts
