Status
Not open for further replies.
1 - 4 of 4 Posts
Win XP pro
ATI 550 PCI analog tuner
some usb 2.0 DVB-T receiver
Nvidia 6600 GT AGP video card
M-audio 7.1 usb sound card
Meedio package for front-end and PVR
ffd-show for processing
zoomplayer for offline playback
silverstone lc-11m with remote/VFD (come with iMon)
possibily Girder
Will be used for playback of offline media as well as viewing live television. I am concerned both with quality and ergonomy.
I think about software supporting this particular hardware.
with best regards
Knut Inge
what do you plan on running for the CPU? I ask just for the fact that you want to use FFdshow.
- Josh
Discussion Starter · #4 ·
I plan on using some AMD s939
*ducking to avoid the feared "thou shalt only use intel p4 for thy scaling purposes" - syndrome*
My machine must be near silent, I wont use water cooling, and I`ll take my chances that new s939 incarnations with two cores etc will be sufficiently supported by ffd-show.
regards
Knut Inge
1 - 4 of 4 Posts
Status
