  • If you've ever wanted to ask questions on industry standards when setting up your home theater, you're in luck! Peter Aylett, 30 year integrator and partner at HTE Acoustic Interior Design will be answering questions until Sun. Nov. 28th! The thread is now open, and you can join in here!
1 - 2 of 2 Posts
Decided when this amp finally dies and that HDMI board goes that I'm going to make a switch. Most likely to Denon. Either the 1000 or the 2000. Yamaha is a no go since it does not have Audyssey.
On my onkyo I have two pre outs for my subs. I have infinity IL 60s and each one has a sub. The demons only have one pre out jack for the subs unless I go to the 3000.
Can I use a splitter jack and plug it in to the pre out and run each cable to my subs or do I need two pre out jacks
1 - 2 of 2 Posts
